I did a video of jupiter with the seestar. the file it output was mp4. i saw a video where someone said i could use asivideostack to do the image from a planet from the seestar on this, and he drags the avi file over to it. i see it only accepts avi. is there a way to save the output as avi instead of mp4?
when you capture, you have to select RAW soft button on the screen.
ah ok. bummer. looks like i have to capture it again then. i did try to convert it but the file errored when trying to process it.
As a general rule, turn on RAW in video mode and also save individual sub-stacks in Stargazing mode, it will use a lot more disk space but you will be happy later on you did. And make back-up copies as soon as possible.
