Hi Kevin, thank you again,
I am using an Ioptron CEM70EC2 mount with a Sky Rover 80mm ED APO scope (native FL=480) with 0.8 reducer (FL=384mm) with a 30mm guidescope FL=125 and ASI120 mini guide camera, so from you previously said, my Step size should be 2000 with MAX RA & DEC Duration being the same, is that right? I think I understand this and where you got it from. I need to learn PHD2 to figure this stuff out too.
I am also going to image with my C11 at F10 and F6.3 one day with OAG, so native FL=2800 and with reducer FL=1764 with ASI 174 Guide Camera with 5.86um pixels, what figures would you recommend here?
If I buy a Hyperstar V4 the C11's FL will be 532mm at F1.9, so I would also need to buy a larger guidescope at FL 500mm or so and use the ASI 174 on that. So extrapolating from your initial figures above the step size would be around 530? Would that be about right?
Also do you know if there some info on how to guide a mount like mine with encoders. I have RA & DEC Aggression set to 20% and calibration data as per your figures and it works ok. It would be nice to know how guide exposure time affects these encoder mount as I would assume the less corrections (ie longer exposure time) would be better, but am limited to max 5 secs on ASIAIR and I really could not tell if it made a difference, sometimes better, sometimes worse.
thanks mate!
cheers..
