I'm thinking of mounting a small TEC (5W maybe) on the back of the PCB, then using the case as the hot side of the TEC. So the case will get warm as the chip gets cold. I know I will need to stop moisture condensing on the chip itself, so maybe a fully-sealed case with a small hole to squirt in dry air-duster gas. The small TEC should work just fine in theory as the chip only dissipates 200mW maximum. Anyone else adopted this mod?
