It had been sunny for the first time in a long time, so I tried to use Seestar to see the sun. Then a Firmware update was performed. However, Seestar said "Update Failed" and did not update, and I cannot use the Seestar app. What should I do?
I would un-install the app completely. Re-install it and then try to connect to the Seestar as it was your first installation.
Thank you for comment. I did un-install the app completely, and re-install , and then connect to Seestar as 1st installation.
I connect to Seestar with Reset button. Then Firmware updating start, and this time it works OK! Thank you!!
Glad i could help. Im quite amazed how good this product is and its getting better and better. Yes there are a few quirks and unstabilities but as long as people report back it seems that they fix this.
