starnet OK, maybe I am wrong, maybe I am right, that is irrelevant, but here are the facts. I looked at the first 20 sub frames of an acquisition of NGC2174 - this is from a "good" sequence, with no lost frames. The JPG of the first sub-frame looks like this (the white circle marks the star I am using as a test, which happens to be HD252464, a magnitude 10 star):
A deep zoom shows that the PSF of the star is quite round, with no trails and it looks similar in all 20 subs:
Here are the time stamps and the X and Y pixel coordinates of this star in the first 20 subs, for a 50 mm aperture, 2MPixel camera and Alt/Az tracking I think this is very good:
Does this support Daemn42's hypothesis or mine? I am no longer sure. The first five frames definitely show consistent movement in a given direction, if the S50 can continuously track each 10-second sub like he says, why can't it do that beyond 10 seconds? Sets two and three show much less movement between subs, but set 4 again shows a lot more movement. If the S50 Alt/Az mount does indeed track continuously the stars movement within the 10-second sub, why can 't it keep doing it for more than 10 seconds, or one minute or longer? And how can it do that with half a degree of mechanical backlash?
In the end, I do not care how it does it, if the lost frames are not inherent to the tracking algorithm then they are a bug and should be fixed. If there is no way to fix this, I can live with less than 100% capture efficiency, what is unacceptable to me is the very limited set of features of the SeeStar app. If I cannot at a minimum start a capture with given RA/Dec coordinates at a programmed time in the future and have it end after a given length of capture, which would let me go to sleep and keep my sanity, this thing is completely useless to me and I cannot see how I can keep using it.
I see that there are ZWO people responding to some messages posted here but they do so rarely and selectively. After my posts, which are not negative, I have stated repeatedly that the S50 has amazing performance for its cost and I am a happy customer, I am probably on a black list or something. But I desperately need these extra features in the SeeStar app because I cannot use it as it is right now.
