My ASI130mm has the same problem on my new laptop HP EliteBook. The camera works fine on me old 32bit system, but not on the new 64bitOS. I've followed the instructions from your troubleshooting page and re-installed the C++ Microsoft thing. Which was already installed, when I put the ASCOM drivers on the new laptop. I've had to check the box next to Microsoft.Net 3.5.1 which ASCOM requires for it to run on Windows 7 could this be a problem?
Every time I un-install re-install the driver I get the same messages as the OP. Plus the unmoveable yellow hazard triangle in the Device and Printers section.
I use the 130 as me guide camera so can use me old laptop until a solution is found.
Regards
Pat.
P.S I've installed the old driver version from me ZWO disc to no avail, same yellow hazard and in windows troubleshooting I have the message camera failed to start. problem with driver error 10.
