I just tried using both MaxImDl w/ACP and The Sky X and neither could get past calibration. It would take the guide image, allow me to choose a stra and calibrate. Then when told to Track it would say it was taking the image and never download anything. Subsequent attempts to take and image failed. It would appear to do so and never download an image. My ASCOM version is 6.6 SP2. MaxImDl is 6.40, and TSX is the very latest build. I have a Universal License. I can't get past this point. I've double checked to be sure the driver is setup properly and in MaxIm I see two choices to set the and either choice ends with the same result, no active guider after calibration.
I have no idea where to go from here. I've tried two softwares with the same results. Intersetly the guider had worked once before a week or so ago and nothing software wise has changed that I'm aware of. This is a Windows 10 Pro 64 computer.
I tried connecting the camera via USB directly to the computer versus the Pegasus with not difference. I have copied the log files and 2 are attached here:
I have no idea where to look on this. After calibration and failed tracking attempts, no image from guider and reads "downloading" for both main chip and guider attempts.
