Two cameras, usb stick and mount uses all of the ports on the ASIAIR. The asi2600mc Pro has two usb out ports, can I plug zwo eaf into one of them or do I need a usb hub for extra connection points? Can you tell I’m new at this?
I use the USB ports on my ASI6200MM all the time. They have been added exactly for this. Just make sure to plug in USB3 devices (the ones with blue USB ports) directly into the ASIAir and you should be fine.
Thank you, the “usb out” on the 2600 mc had me stumped. Why not just label it “usb”?
Dunno. Maybe because those two ports provide 5V output to power devices and the USB3 (blue) port doesn't?
