AymenAissa I played with the prism and focuser, however, the focus point seems to be lower than the well depth. I tried pulling the prism up a bit to compensate for the distance and i was able to get the 174 focused however that generated a horrible vignetting where the lower screen is dark and the upper side is fully bright.
Check these two things
1 The direction of the ASI174 sensor and OAG prism are the same
2 Make sure the adapter on the telescope side was not block the OAG-L prism.
AymenAissa I now mounted the full setup on the Askar 400 (Backfocus not required) to test the OAG and added an extra spacer (16mm) between the main camera and the EFW to give the guiding camera extra room for movement. This way I could achieve focus on both cameras, however the vignetting is still present even when trying to lower the prism at its maximum. This is not letting me see more that 2 faint stars on my guiding 🙁
If you want to reach the 55mm back focus length,
You can replace the 11mm adapter on the camera with a M42 5mm tilt plate, then add a 1mm spacer to get 55mm back focus.
