Hello!
I'm preparing our livestreams for the April 8th eclipse, and we're working on solar guiding. Here's my (guiding) setup:
- Macbook pro with ASICAP
- AM5 mount
- Zwo F4 guide scope with Thousand Oaks filter
- asi120mm-mini connected to MBP via USB-C
- asi120mm-mini connected to AM5 ST4 port via standard RJ11 cable
When I start running the autoguide, I see the "+" on the Moon (my test subject last night), and the four arrows flash as though it's issuing corrections, but I see no movement on the mount.
Is there something I'm missing? I tried for hours last night (even trying two RJ11 cables and two different asi120mm-mini cams).
Thank you! -- Paul
