SFn8CieR Yes I use Siril but never knew it could detect tilt. Where can you find this feature?
I don't know about other OS, but on macos, there is a hamburger icon (three parall horizontal lines) near the top left of the Siril main window.
Click on that to get a contextual menu, one item is "Image Information." That is a submenu with an item named "Dynamic PSF." Select that.
It opens an aux window called (what else) Dynamic PSF. Towards the bottom right are some icons, one of which looks like a trepezoid with lines connecting diagonals. Click on that ans you will get a tilt report in the main window.
Instead of Dynamic PSF, if you click on aberration instpector, you'll get tat 3x3 array of corner and central part of the full image -- saves a lot of time doing it yourself.
