As a new Seestar S50 owner I opened an account and started using this forum, and I have bumped into a couple of problems that are very obvious. Somebody should fix them. If there are workarounds, let me know, but they look like everyone should experience them the same way.
When I click on my User Name in the top right corner, and click on "Profile", the page shows a loading circle and "The requested resource was not found" error is shown. There is no way for me to open my Profile. Does anyone have this problem? If not, it may be related to my username having a space in it. To the admins: if it's because of the space you either need to not allow spaces in usernames during registration, or fix the URL parsing so the page loads. The space is converted to %20 in the URL (which is correct) but the page fails to load, so I can't see or edit my profile.
There are 2 "Home" links - the logo and the "Home" text link. The logo points to the forum's home, but the "Home" button points to the old website https://astronomy-imaging-camera.com instead of the new website https://www.zwoastro.com. Also, I keep accidentally hitting the "Home" link, thinking I'll get to the forum homepage. From the UI perspective, this should be renamed to something else, like "ZWO Home", because it's confusing the way it is.
I'm a professional web designer, with 23 years in business, so I just thought I should mention this to the admins.
When posting, uploading images works, but pasting an image from clipboard doesn't work. It says "uploading" for a while, but then there is the error "Oops! Something went wrong. Please reload the page and try again.". The image I was trying to post was fairly small, so it's not the size. In any case, this is not how it should work. Most forums allow pasting images (which is very useful!), but even the older forums that don't allow this, don't act as they do only to throw up an error.
