When I stack my fits I;m given a TIF file. However that tiff file is just a pure black image no matter what program I open it with? What am I doing wrong?
Blank Tif
- What equipment are you using?
- What object did you image?
- What software do you use to view it?
- You might need to stretch the image.
JohnD
It seems your file is still linear. It is 100% normal if you didn't stretch it. You can probably use photoshop to stretch it with the histogram tool but it may not be that easy as Photoshop is not really designed to handle linear astophotography data. The more usual workflow is to use the stacking program that you used to stretch the image before importing it to Photoshop.
7 days later
I had the same problem. When I selected image-auto tone in PS the image came up, but was mono and had a grid over the image. I do not mind the conversion to mono, but I would sure like to make the grid go away.
