Here we go. Star is Alioth. 3 second exposure ASI6200MC with gain 100. Rokinon 135/T2.2 with ZWO EOS adapter with 3rd GEN filter drawer (the latest, that finally does not leak significant light). Rokinon is stopped down to f/3.1 with an aperture mask (ergo, no confusing spikes for the Bahtinov focusing)
First screenshot: Kase Bahtinov mask, no filter (empty filter holder), EAF at 21248:
Second screenshot: nothing changed (i.e., EAF still at 21248), but swapped in a filter holder with a Baader Semi-APO that is supposed to be 2mm thick. The backfocus presumably changed by 0.66mm. :
Third screenshot: still with Baader filter, refocused to center Bahtinov spike. EAF now reads 21503:
So, I see a 255 EAF step change for the 2mm filter, presumably 667 µm change, or 2.61 µm per EAF step (my FSQ-85 has 4.2µm per EAF step).
I will go enjoy looking at backfocus now, after I test the Astronomik L1's EAF delta and the Radian narrowband filter EAF delta (that is where you really need the Kase Bahtinov mask). Those two are suppose to be about 1mm and 3mm respectively, but I want to measure it than guessing it.
I can then refocus instantly (perhaps just refocus for no-filter case when temperature changes) when I change filters. Don't even need the Bahtinov mask anymore once I get the Astronomik and the Radian EAF deltas.
Painless! Even with just a filter simple drawer -- with an EFW, I won't even need to go outdoors.
Kevin, re etched glass Bahtinov masks, see why I like them for their cleanliness? The Bahtinov core does not bloat in brightness, and there are no extraneous splikes. Especially when compared to the 3D printed crap. The R, G and B chroma channels overlap perfectly. You get what you pay for, and it pays off with tight stars (if the OTA is up to it -- the darn Rokinon is pretty darn good, from this Bahtinov image).
P.S. someone is lying about their glass thickness! The Astronomik L1 (claim 1mm glass) and the Baader Semi-APO (claim 2mm glass) are essentially parfocal! I can't focus any better with the Bahtinov (and we saw the huge difference between no-filter and the Baader). They have the same glass thicknesses. This hobby is full of charlatans.
P.P.S. I tried the Baader Neodymium (claimed 2mm thick) and it has a different focus than the Astronomik and the Semi-APO. So, the conclusion is Semi-APO has the same thickness as the Astronomik -- it is most certainly not 2mm thick.
P.P.P.S. The Baader Neodymium gave an EAF step of 21700. I then swapped in an Optolong UV/IR cut filter (claimed also 2mm thick glass)-- parfocal with the Neodymium. So much of a coincidence, so both Neodymium and Optolong UV/IR Cut are 2mm with very high probability. (No, I am not going to put calipers on a glass filter!)
L1/Semi APO delta from no-filter was 255. 2mm glass from no-filter is 452 EAF steps. Half of that is 226, not 255. So, the L1/Semi-APO is thicker than 1mm. (I have read somewhere that the Astronomic is 1.1mm, not 1.0mm, but no confirmation from Astronomics. )
If 2mm (since Optolong and Baader Neodymium (both claim 2mm), the 226 step per mm of glass (333 µm of backfocus) is probably somewhat reliable. This makes the EAF scale 1.47 µm per EAF step.
And if the Astronomik L1 is 1.1mm thich, it would be 1.1*226 EAF steps, or 249 EAF steps, which is pretty darn close to the focused Astronomik L1 of 255 steps.
So, my guess is Astronomik L1 is 1.1mm or so thick, and the Baader Semi-APO is the same (since they are parfocal). And Baader Neodymium and Optolong UV/IR cut are both parfocal at 2mm.
Whew. No more Baader filters for me. Their specs cannot be relied on.
It is amazing what you learn about this hobby, once you dig deeper.
Going forward, I will be using no-filter to represent a glass delta of 0mm, Astronomik L1 to represent a 1.1mm glass (actual EAF 255), and Optolong UV/IR cut to represent a 2mm glass (actual 452 EAF steps).
Now to see if I can actually measure the Radian, with its very narrowband passbands. If not, I have a Chroma 2" Luminance filter coming my way, and that too claims 3mm glass. But, at least for now, I have 0mm, 0.3663mm and 0.667mm for backfocus deltas.
P4.S. Wow, more inaccuracies. This is what a focused Radian Quadband looks like. Notice the EAF setting? 21436. Remember that no-filter EAF step was 21248? This makes the Radian just 188 EAF steps from the no filter case! It is not 3mm, it is not 2mm, it is not even 1mm. 1mm glass is about 226 EAF steps, so the Radian glass is barely 0.83mm thick! I rechecked the no-filter case, and the EAF remained at 21248, so no gear slippage (I use a 0.8MOD follow-focus gears, with the follow focus ring gear that is buit into the Cine version of the Samyang/Rokinon 135). Zero remained zero.
(Notice that Alioth's neighbors are Meridian flipped :-)
I await the Chroma to get 3mm glass....
Kevin, notice that the exposure time for the narrowband Radian remains 3 sec? Another advantage of these masks is how bright they are.
