Hah! I just figured out how to very easily install a fixed iris on the Samyang/Rikonon 135!
There is no need to remove anything but the front glass group, and that involves a simple lens spanner without teeny tiny screw, nor deal with fragile cables. And it is completely independent of whether the Samyang lens has a EOS, Nikon or Sony mount.
Then apply some glue to the iris mount just as if the iris is outside the barrel, and drop the fixed iris in place.
Basically, glue the top piece to the bottom piece in this photo, with the bottom piece not removed from the lens barrel:
If you look down the lens from the front glass of your current lens, you should be able to see the bottom piece of that photo. The top piece comes from the machine shop.
I am going to fabricate a new fixed iris, but this time, not adding the ZWO fisheye retaining rings, but just get the machine shop to create that small aperture directly. The mitered hole that they mill appears to be smooth enough.
The machined plate is 1.5mm thick, but even that can cause some aperture vignetting for large angles from the optical axis. So I have them miter the hole down to an almost knife edge (0.2mm thick).
So... ta da... I can try this on the Rikonon Cine 135/T2.2, which so far has not has the crap at the back removed. That will prove if I can glue a new fixed iris without removing anything but the front glass. I will still need to remove the bayonet plate and replace with M54 and tilt plates to be able to actually use it; but that is independent of the iris.
Here is an offer you can't refuse... if you want to use a fixed f/3.5 (my -1.5 f-stop rule :-) to get rid of the diffraction spikes, I will get two copies of iris plates machined, and mail one to you (gratis, of course, it is just a couple of dozen bucks). Be forewarned that once you glue it in place, you can only use something slower than f/3.5 from then on. Or use double stick scotch tape, and hope it does not fall off :-)
Or (since there is no volume discount other than shipping from the machine shop anyway), tell me what f-stop you prefer, and I will create a second drawing for them. It might be a week before I get to this, so you can sleep on it for a few days. (I will need your street address; send it by email to me at w7ay_at_comcast.net.)
Don't want spikes? It looks like a 3 minute operation that even the unwashed can do, as long as they have a lens spanner (metal crazy glue does take 30 seconds to set, and 24 hours to cure) -- I can believe that some of the SeeStar types have never seen a lens spanner.
I had used some M42 tubes with some weight on it to apply pressure on the plate when the glue was curing; I think you can still do it with the iris assembly in the Samyang barrel as long as you secure the barrel vertically.
This is a clearer view of the iris assembly. The machined fixed iris is glued to that flat annulus around the Samyang iris.
