bambi851 Can you increase the max steps size please?
It is available with the latest firmware. But you need to update the EAF firmware (Windows, macos, Linux versions available). Search the ZWO web site.
Be sure the EAF is the only ZWO product that is connected to your computer when you update it, or you may brick the other devices, like bricking an EFW (happened to at least two people on this forum so far).
Then use ASIStudio to change the max step size in the Focuser control's advanced menu. You may already have firmware that can handle it, in which case, just change the max step size in ASIStudio.
I'm not really sure why it would have a max step size.
Its to keep the EAF from hitting one of the mechanical focuser's limits. You may not like it, but some people use it as a security blanket. Step of 0 is set to one of the limits of the draw tube travel, and max step size is set to the other limit of the draw tube travel. This way, the EAF will not hit one of the mechanical limits.
No, as standard with ZWO's practice, there are no instructions. You get what you paid for (low bidder).
