UPDATE: So, I did some searching online and found that the telescope can apparently achieve a limiting magnitude of approximately 15 under optimal conditions when using 3 minute (18x10s exposure) stacks.
Can someone confirm if this is indeed the case, or is the answer I found online incorrect and if so, what is the actual limiting magnitude of the Seestar S50 under optimal conditions?
