Is there anyway to get 12bit output from a ASI120MM using trhe ASCOM drivers?
I've tried with both Nebulosity and APT and am only getting 8bit?
I would like 12bit as I want to experiment with deep sky imaging with the camera.
James
we will try to improve the driver to support DSO imaging
here is a beta version
http://zwoug.org/viewtopic.php?f=21&t=1552&start=10
Sam wrote:we will try to improve the driver to support DSO imaging here is a beta version http://zwoug.org/viewtopic.php?f=21&t=1552&start=10
Having now tried these drivers several times in both APT and Nebulosity I find they have some big problems.
The gain keeps going back to 100 every time the setup dialog box is display, but worse is I can only ever take one image using APT and none using Nebulosity. No error message is given just no image displayed.
The cmera works fine with FireCapture so I'll keep using that for deep sky as well as lunar / planetary imaging for now.
that's wired
because somebody's feedback is posstive
just bin2 problem is there
