Hi there. I would like to use SkySafari with my AM5 through the ASIair. I am able to control the AM5 with the SKySafari no problem when I use the AM5 wifi directly. I can use SkySafari with ASIair with a non ZWO AM5 mount no problem. However I cannot use SkySafari with ASIair and AM5 in otherwords I cannot control AM5 goto using SkySafari if I am using the ASIair. This has rendered the SKySafari useless to me as a Telescope control. I use the SkySafari for other things but I cannot connect it to the AM5 through ASIair. DO you think this is related to the wifi on the AM5 mount and there needs to be a way to turn it off. I see this is a feature requirements that needs to be implemented.
Does anyone have a solution?
Thank you.
