Hello, my equipment is as follows:
- AZ SynScan GOTO mount
- Mak 127 with focal reducer x0.5
- ASIAIR Plus
- ASI 224 MC camera
All controlled from an iPad with the Beta version of the App by selecting "Skywatcher SynScan Beta".
Things happen to me that I don't get to understand, like for example, after aligning the mount to two stars (without connecting the ASIAIR yet), after centering the first star, it automatically moves the mount towards the second one leaving it quite far away from the center in the position, let's call it X, finishing centering it myself manually and showing the "Correct Alignment" warning. Well, when I connect the ASIAIR it moves the mount to another position (possibly the N) and when from the App I tell it to look for the second star that I centered in the alignment, it doesn't leave it in the center, it leaves it in the X position.
The App's GOTO never centers the objects and I have to center them manually because it never does plate solving, even sometimes, once the object is centered, it doesn't match the App's map.
I am reporting all this to the technical team through the App, but I get the impression that with each update of the beta version it works worse and worse.
Can it be a malfunction of the mount, can it still be a malfunction of the App in the absence of correcting these problems?
Thanks
