Hi all, quick question:
Is it compatible the 2600mc duo camera with a Celestron c11 (Schmidt-Cassegrain) ? Does it work properly or does is it incompatible due to the image circle?
Thank you,
Hi,
on a normal C11, you do not have a corrected image cycle of 44 mm on a C11 EHD, yes
Clear skies Peter https://pixlimit.com
Hi pixlimit i'm adding in the C11 the 0.63 celestron reducer for that purpose,
Could I use the 2600mc with it? Or it will be too small the image circle?
Thanks in advance, Isidro
Hi, for the main sensor it should be fine, after that there is vignetting. but the guiding sensor should be able to handle it...
CS Peter https://pixlimit.com
Thank you mate!
