New ASIAIR + to improve portability. Currently ASIAIR powered by 12.V 10A supply and powering via 12V ports 294MM camera and AM5. App is showing 12.5V as min voltage. Mount stationary as I am creating darks files. Camera randomly appears to disconnect. If I open camera tab and disconnect and reconnect camera it works again. I know this is generally the result of power issues, but monitoring voltage I have never seen voltage to go below 12.5V. As this is a new air, installed app version is 2.1.2.
Also is there a way to bypass the data integrity check each time I start the app?
