Which driver in the AIR Plus are people using for their HEM44 mounts ? I've tried several listed iOptron drivers and have not had good success. I'm using an ASIAir Plus that has the latest firmware update. Thanks !
You should be able to use the GEM45 (second generation) driver. Note that the mount may need to be connected to the USB-hub on a ZWO camera and not directly into the ASIAir for the connection to work.
HTH, Wouter
OK- thanks, I'll give that a go. I used to have a GEM45, so I already knew about the issues with the iOptron USB ports. Clear skies !
FYI- my issues were due to buggy firmware on the HEM44. Updating to the latest firmware takes care of the problem, and the HEM27 driver works fine.
