I usually image the same target over multiple nights and I will select the image from the previous night (from the file), then hit Goto. The problem is that I may not be centered on a certain object. For example, I've been imaging M81, but have it framed to have M82 in the field of view. So, when I do this, "Target" is the name and goes into the FITS File, but I want M81. I don't use the plan mode as I image one target per night (I'm out for 2-4 hours per night since I cannot image from home). Is there a way to change "Target" to whatever name I wish?
