I have recently purchased the EFW 7x36mm and I am wondering about the recommended connection method to my ASI 2600mm. For the record, I am not using an OAG.
It seems the following two methods exist:
I have read it is better to remove the tilt plate, then attach the EFW directly to the camera, because of filters being closer to the sensor, less light leak risk, less risk of adapters getting loose etc.. - can you confirm this?
Currently I am following method 1 with the tilt plate on, T2-T2 adapter, then EFW.
If I changed to method 2, in detail I guess that would be: camera --> darkening ring --> EFW --> darkening ring --> ...
What would I need on the other side of the EFW? Following the diagram, I would need a 22.5 mm M42M-M48F extender?
