SFn8CieR I will also try short exposures as I think that this will work with the information you have given me.
Long exposures can have problems with mounts that moves a lot while exposing a guide frame, so I won't recommend really long exposures. I would rather use shorter exposures, but issue correction pulses less often.
What many people don't realize is that when you are taking a guide exposure to estimate the new cetroid of a star, that exposure does not give you a pinpoint star. The star is moving while you are taking the exposure! So you end up with a elongated star, and that is harder to estimate xcentroid. At the end of the exposure, the star is at one of the two ends of the elongation... but the software has no idea which end of the elongation was the start, and which is at the end! The result is that you get poor guiding.
With strainwave gear mount, the star can move half an arc second (angle) if you use a one second (time) exposure. Because of this, strain wave mounts need very fact exposures, so as not too fall into this elongation trap.
The star does not move from point to point. In fact, the movement is like a sawtooth. You can see a desciption of that in the discussionn here (post #6, #74, #84 in a very long thread):
https://bbs.zwoastro.com/d/15989-getting-the-best-performance-from-my-am5/6
https://bbs.zwoastro.com/d/15989-getting-the-best-performance-from-my-am5/74
https://bbs.zwoastro.com/d/15989-getting-the-best-performance-from-my-am5/84
Once you understand the sawtooth graph, everything will become clear and autoguiding will no longer be mysterious. Please try to understand the sawtooth. I promise it is worth it for the rest of your autoguiding life :-).
The problem is that people have always assume that when you take a guide exposure you actually get the location of a star. You don't. You get a line that is traced by the sawtooth.
Now, you have a good mount, so your sawtooth is very small. The ZWO mount is so poor that I have given up helping people. The ZWO mount is a lost cause.
