Tech@ZWO Hi,
I add myself to the list of those interested by this function :-) I bought recently a new ASI Air plus to operate 2 setups simultaneously and it would be great to be able to transfer plans, dark libs, and so on from an asiAir to another one.
In order to have "ready to go" setups, I aim to attach a dedicated asiAir to the material cases and I could use more than 2 in the future.
For dark libs, i suppose it is possible just to copy the fits file corresponding to the master dark on the new AsiAir (i did not try it yet). For plans, as the import function exists through CSV format, i suppose it's not a long way to code the export function through the same format, or, with more metadata than coordinates (especially number of frames, duration, gain...), a "JSON like" format with export/import dedicated to AsiAir.
Thanks for the regular developments of this good product.
