Hi, last night 8th June 2024, was clear most of the night so I set up but did no imaging due to problems with the Air pro then I swapped to my plus but still had the same issue in that the mount kept disconnecting. I changed batteries, all cables but all to no avail, so I had to pack up. Today, Sunday 9th June I tried again but without my scope, help to prevent any cable issues, when I asked it to go to the home position, the dec just kept spinning around, not fast but usual speed, I had to close everything down and switched over to the AM5 app, everything worked fine there, I decided to go back to the AAP and everything seemed OK. The firmware for the AM5 is all up-to-date ( mount and handset). Clear nights are very valuable here in the UK and far between. Can anyone help please.
