Thank you for the suggestions. It does not matter whether I go with the ASCOM route or the native drivers. The result is the same. However, after try various connction methods the one that seems to work the best is to start APT first and get an image, albeit an upside down image, with the ASI220MM-Mini. Once I have that image, then I start PHD2, connect, and hit the looping button. An image appears, it may take a few seconds, but I do get an image and it is right-side up. As soon as that image appears I immediately hit the disconnect button on APT and keep my fingers crossed that PHD2 still is working. Right now I have had a stable connection for over an hour.
Somehow, I do not think this is the way the ASI220MM-Mini is supposed to work with PHD2. I may be wrong but what I have to do does not seem right.
I am using PHD2 2.6.13dev4.
