Hi,
Over the last two days I have been toying with using the SDK as provided on the ZWO homepage in Linux (64-bit) to control my brand new ASI-120MM-S camera.
I have gotten everything to work, but along the way I encountered a number of small issues. I hope that they can be improved in an upcoming release. I list them below for reference.
1. Packaging of the library
I found the most recent release on the page http://www.zwoptical.com/Eng/Software/index.asp.
The link as found on that page says "v0.0.905" for Linux and Mac, and it leads to the following URL: http://www.zwoptical.com/software/ASI_linux_mac_SDK.tar.
When unpacking (untarring) the downloaded file, it turns out that it contains a single file ASI_linux_mac_SDK.tar.bz2, which is an archive itself. This unpacks to three directories, "include", "lib", and "demo".
The nested packing is superfluous; I think it is also good practice to put the version number in the filename of the tar file, and to unpack to a directory that has the same name as the tar file minus its extension (.tar.bz2), which should contain the three directories. So ideally, dowloading and unpacking would look like this:
$ wget http://www.zwoptical.com/software/ASI_linux_mac_SDK_v0.0.905.tar.bz2
$ tar xf ASI_linux_mac_SDK_v0.0.905.tar.bz2
$ find -type d
./ASI_linux_mac_SDK_v0.0.905
./ASI_linux_mac_SDK_v0.0.905/lib
./ASI_linux_mac_SDK_v0.0.905/lib/x86
./ASI_linux_mac_SDK_v0.0.905/lib/x64
./ASI_linux_mac_SDK_v0.0.905/lib/armv6
./ASI_linux_mac_SDK_v0.0.905/lib/mac64
./ASI_linux_mac_SDK_v0.0.905/lib/armv5
./ASI_linux_mac_SDK_v0.0.905/lib/mac32
./ASI_linux_mac_SDK_v0.0.905/lib/armhf
./ASI_linux_mac_SDK_v0.0.905/include
./ASI_linux_mac_SDK_v0.0.905/demo
./ASI_linux_mac_SDK_v0.0.905/demo/bin
./ASI_linux_mac_SDK_v0.0.905/demo/bin/x86
./ASI_linux_mac_SDK_v0.0.905/demo/bin/armv6
./ASI_linux_mac_SDK_v0.0.905/demo/bin/mac64
./ASI_linux_mac_SDK_v0.0.905/demo/bin/armv5
2. Version number mismatch.
The " http://www.zwoptical.com/Eng/Software/index.asp" page claims the library is version 0.0.905, yet the files in the SDK have version numbers "0.0.0918". This suggests that the web page wasn't properly updated.
3. Definition of ASICAMERA_API symbol
In the header file, the fragment where ASICAMERA is defined currently reads:
#ifdef _WINDOWS
#define ASICAMERA_API __declspec(dllexport)
#elif defined _LIN
#endif
To obtain the desired behavior, we are forced to compile with symbol "_LIN" defined in Linux. This requirement is undocumented. It is also not very logical; the ASICAMERA_API symbol is present to allow compilation of the library as a DLL in Windows. In all other environements, the ASICAMERA_API symbol should just be #defined as nothing. So I think a better solution is this:
#ifdef _WINDOWS
#else
#endif
4. Three issues with using the library in C (rather than C++)
4.1. Definition of ASI_Control_TYPE
There are a bunch of #defines that are triggered only if the header file is processed in C (rather than C++):
#ifndef __cplusplus
#define ASI_Control_TYPE int
#define ASI_BOOL int
#define ASI_ERROR_CODE int
#define ASI_FLIP_STATUS int
#define ASI_IMG_TYPE int
#define ASI_GUIDE_DIRECTION int
#define ASI_BAYER_PATTERN int
#endif
However, these defines are defined below the definition of ASI_CONTROL_CAPS, which means that C compilation breaks, since the symbol ASI_Control_TYPE is required in the definition of the ASI_CONTROL_CAPS struct.
It is at least needed to move the block of #defines above the definition of struct ASI_CONTROL_CAPS.
A better solution still would be to remove these #defines alltogether, but define the "ASI_Control_TYPE" using a typedef, as is done for all other enum types:
typedef enum ASI_Control_TYPE {
ASI_GAIN,
ASI_EXPOSURE,
ASI_GAMMA,
ASI_WB_R,
ASI_WB_B,
ASI_BRIGHTNESS,
ASI_BANDWIDTHOVERLOAD,
ASI_OVERCLOCK,
ASI_TEMPERATURE,
ASI_FLIP,
ASI_AutoExpMaxGain,
ASI_AutoExpMaxExp,
ASI_AutoExpMaxBrightness,
} ASI_Control_TYPE;
4.2. using "bool" type.
The definition of ASIEnableDarkSubtract() uses a "bool" type, which doesn't by default exist in C:
ASICAMERA_API ASI_ERROR_CODE ASIEnableDarkSubtract(int iCameraID, char *pcBMPPath, bool *bIsSubDarkWorking);
Possible solutions:
- use an ASI_BOOL type instead;
- use bool, but include <stdbool.h> for C compilation, which makes sure that 'bool' is an alias for the existing type _Bool.
4.3. Linking the library
The library uses C++ internally (which is fine), but this means that a C++-aware linker must be used rather than a standard linker.
For example, to build a C program, the following fails in Linux:
gcc -Iinclude -W -Wall -O testprog.c lib/x64/libASICamera2.a -lusb-1.0 -lpthread
To make this work, you must do this:
g++ -Iinclude -W -Wall -O testprog.c lib/x64/libASICamera2.a -lusb-1.0 -lpthread
5. Typo in the header file.
The ASI_CONTROL_CAPS struct defines a field with name "MaxVale", this should be "MaxValue".
6. Behavior of the program.
6.1. Executing ASIGetControlCaps() on the "AutoExpMaxBrightness" control returns 11 (ASI_AutoExpMaxExp) as the ControlType value.
I am pretty sure that should be ASI_AutoExpMaxBrightness.
6.2. libusb_close() called twice
libusb_close() is called twice when closing a camera using ASICloseCamera(), the first time with the proper device parameter, the next time with NULL. I found this while inspecting what libASICamera2 is doing under the hood.
