> "For the AM7, ZWO is still collecting user needs to determine the product specifications"
ASIMount-ZWO It should be able to compete with the HAE69. Ideally, it would have a payload capacity of about 70lb/32kg and a weight of about 20 lb/9 kg. It would also feature built-in cable management and EQ and AZ modes.
It would be nice if it also had the same type of screw pins (not clutches) from the Sky-Watcher Wave 150i that allows balancing the OTA in Dec and RA.
I want to be able to use a 14" Celestron EdgeHD on it, with counterweights if necessary.
