The ASI2600 & ASI6200 flange backfocus distance of 17.5mm is too long to use most lenses for non-astro imaging. Even with the 5mm leveling plate removed, it is still 12.5mm, and MFT (micro 4/3) backfocus is 19.25mm. MFT cameras are sufficient for many applications, even if the full chip area cannot be used. The ASI2600MM & ASI6200MM are cooled, 16-bit with no amp noise, and there is no ZWO alternative. (The ASI294MM has amp glow for 5 minute exposures, and the ASI432MM is not cooled).
Would it be possible to reduce the backfocus distance, with perhaps an additional compensating plate to maintain the existing distance for backward compatibility? Even an extra 5 mm for the ASI2600MM would be interesting. Maybe even optionally remove the dew heater ? For non-astro imaging the camera and lens must also be separated by the metal plate of the camera box, which makes backfocus even more difficult.
