Hi there,
I have an EAF and I think it’s causing some issues with my setup. When it’s plugged in and connected to software, I think it interrupts the camera, as I get a failure with photos. When it’s not plugged in, the system seems to work fine.
Is there a way to check this out? I was sent a pdf showing how to debug, but I tried the same technique out with the focuser and there is a different Regedit system.
