When I connect the ASIAIR to the power cable and camera cable and turn on the ASIAIR, the camera fan does not spin. Additionally, the camera name does not appear in the app's camera selection options, indicating that the camera is not receiving power. Of course, the output port on the ASIAIR is turned on.
In this situation, if I turn off the ASIAIR, disconnect the cable from the 6200MM, connect it to my 2600MM, and turn the ASIAIR back on, the fan immediately starts spinning, indicating that the ASIAIR, cables, and app are functioning properly.
This suggests that the power cable connection to the 6200MM is suspect. I checked to ensure the cable was properly connected, pushed it in a bit, and tried reconnecting at different angles, but it doesn't always power on.
However, sometimes it does power on by chance, and once it does, it stays powered on. Some instances of this happening include:
Turning the ASIAIR output port off and on made it power on.
Connecting it to a different ASIAIR made it power on.
After connecting it to another ASIAIR, it powered on even when returned to the original ASIAIR.
Despite these instances, there are times when it doesn't power on even if I turn the ASIAIR output port off and on, connect it to a different ASIAIR, or change the cables. Thus, the power-on method lacks consistency and only occasionally works by chance. Is this a malfunction?
・Even when connecting the ASIAIR, power cable, and camera cable, the camera's fan does not spin, and the camera name does not appear in the app. It seems that no power is being supplied to the camera.
・The ASIAIR output port is turned ON.
・When connecting another 2600MM camera with the same setup, it operates normally, and the fan spins, so the issue is not with the ASIAIR, cables, or the app.
・Suspecting a problem with the power cable connection to the 6200MM camera, I have checked and reinserted the cable at different angles multiple times, but it often does not power on.
・Occasionally, the camera does power on, and once it is powered, it continues to stay on.
・Triggers for powering on include toggling the ASIAIR output port OFF and ON or connecting to a different ASIAIR and then back.
・However, these methods are inconsistent, and the camera often fails to power on.
In summary, the 6200MM camera powers on intermittently, but there is no consistent method to ensure it powers on.
