Hi,
maybe someone of you has an idea what is going on with my AM5.
After I updated to the latest firmware (1.5.2) my AM5 sometimes stops while slewing with two beeps. It it does not matter matter which software started the slewing process. I use NINA for imaging, but it also happened while using the ASI Mount software.
Tracking seems to work fine but going to a target, a meridian flip or a simple go to home position can randomly stop the mount. I can repeat the slewing command and the mount will finish the slewing process but for unintended operation this is not usable anymore.
I did not change any software configuration, I only updated the firmware. I did not have this behavior with the old firmware (1.3.7).
Maybe someone has an idea or ZWO can provide the old firmware, so I can downgrade if possible.
Thank you
Markus
