I need to adjust the tilt of my asi2600mm but I can’t get the camera of the filterwheel. It is stuck! Any tricks to solve this? And if I can’t get it loose, can I adjust tilt with the separate tilt adjuster of zwo in front of the filterwheel?
Cheers,
Mark
mavdg What is the model of your EFW? and how did you connect it via screws or thread? Could you take a pic of the connection position? thanks.
I just recalled that the EFW is indeed screwed to the camera! That is what happens when you have your gear remotely taken care of, I just forgot how it is connected. Case closed, THANKS
