Hello,
I don't know if someone has alreday been faced with this issue but I'm a bit blocked so far.
My seestar have not been used for a month or so.
Yesterday I connected the unit to my tablet (as usual) and everything was as usual (the unit fan/motor making noise, unit rotating well but no move of the arm).I then performed the firmware upgrade to version 2.95.
After installation I reconnected the table to the seestar and wanted to do some landscape shooting but while i can hear some motor noise the unit is not rotating and the arm stays in closed position... If I switch off the unit the rotation starts but the arm remains low.
I tried to connect with my iphone too without success but strangely it asked to redo the firmware update of the seestar which I did (successfully again). From there same situation as above (arm in off position not moving).
Do anyone has ever faced this situation ?
Thanks in advance
P.
