johnpd ... Hi John, I updated the application using the "Firmware Upgrade Tool" package. It is designed for EAF, but it has freshly compiled libraries that other components also use. So I downloaded the libraries to my ASIStudia installation and tried to capture meteors, not at night, but simply simulate during the day, and the videos started to save. It only took a few seconds, but with each beep it was saved. And yes, I also think that the image is recorded for a few seconds in the camera's memory (depending on the selected quality and recording time) and in detection mode it is overflowed to avi on disk.
The only thing that worked for me now (at night, during my first test) was that the data flowed smoothly to disk. I wouldn't mind it as an option with the ability to shorten the length to a certain size for easier processing.
The package contains the file fwupdate_linux.zip, at least for me, because I use Linux and there are directories in it and they contain newly compiled libraries. I copied these directories to my installation, thereby updating the versions of these libraries from 2022 to 2025.
Pavel
