I have quite a few guide and planetary cameras I use with Asiair for guidng and for some reason when applying darks in Asiair in the guiding advanced tab, no matter what gain value I set for 0.5s or 1s guide exposure lengths, the darks do not get applied and the guide window is always light grey compared to my 120, 290 and 678 cameras I use for guiding that are dark rich black. The stars show up fine but the sky is light grey. Is that normal with the 220mm mini? I have tried with and without a uvir cut to verify it is not due to higher NIR response too without any change.
Zwo, can you look into this as it is the same on all 4 asiair’s that I have.
