Good day Sam,
To bridge the 5mt limit of an USB cable, I am experimenting with a SILEX SX-DS-4000U2 USB-Ethernet server.
I connect with a HUB my LS6" mount, EOS 1100D Optec derotator to one USB port of the SILEX, and the ASI120MC to the other USB port of the SILEX.
Than with a cat5 cable I go the gig switch and from there to my laptop.
All the connected devices are reported as local devices on my laptop, a sucessfully connected.
see print screen
The four devices are from the top:
1) canon EOS 1100D DRSL camera
2) Optec dreotator
3) Meade telescope mount
4) Zwo ASI 102MC
if I start the programs that controls the devices 1, 2 or 3 (one by one, or all together) they all works as they should.
If I start the program (fireCapture or PHD2) to control device 4 the ASI120MC (on his own, or together with the other programs) the ASI does not produce any images, FireCapture return the error 'capture failed' and the SX-DS-4000U2 crash.
I have to disconnect the power to get it going again.
All the drivers for everything are up to date and so is all the software.
I tried also an other webcam with this setup and it works ok.
Just before the SILEX crash I get the error that the ASI Timed out.
Can you please advise how could I solve this problem?
Thanks and best regards
Marco
