All seems to be fine with the new update, but could you please explain the hard & soft video modes as these make no sense, as the soft option appears to offer using the mobile device as a hand warmer ?.
The-Patrician I saved a 10sec video in both modes and theres a big difference in file size. The MP4 format is also switching between High@L4 and High@L3 so i guess one format is compressed and then with loss compared to the file with bigger file size?
Think i was wrong. Opened the wrong files when comparing so have to re-test later. It could probably be different streaming format when using RTSP. But to be sure we should save i.e 10sek in each setting and compare the codec format stored.
You May have missed the point, when you go to the video decode mode, it says "Soft Selection" - A must hand warmer in winter, heavy compatibility applicable to all smart phone systems
The-Patrician This is making me scratch my head! What the heck are they even talking about? 🤣🤣🤣🤣🤣🤣
I got your point but wanted to find out the difference and answer what the "handwarmer" vs "soft" did. Anyhow its not new that things like this gets lost in translation. And for me its still a mystery that companies doesn't use i.e google translate or people with a little more skills in foreign language.
