I am using iOS and ASI AIR V2.2 2024 08.30
So far the issues i've experienced are with the ASI2600 MC Duo when using Autorun I can no longer set the gain to -25 (It is possible to set it to -25 under the camera tab but this changes as soon as I start the Autorun, but the bug below can trip you up into to thinking it's -25 when it isn't).
If I do an autorun with multiple sets of gain settings the indicator doesn't update. IE I did a 20 flats at 100 gain and 20 flats at 0 gain and the indicator at the bottom of the screen only said 100 gain. I did check the save files and those were at the correct gain settings. It will also happen if I manually set the gain to -25 and start taking flats at gain 0.
When I shoot flats with Auto exposure and finish the set, then change the Flats to Bias in Autorun it used to have the ability to pick up the exposure from the flats. It doesn't seem like you can do this anymore so you have to manually go to your flats and see how long they were, which is prone to mistakes since the units are different.
