Does the two inch filter from their website fit onto the Seestar or what kind of adapter do I need? Thanks much
Eposone79 What filter are you talking about? The S50 only accepts a press fit 50mm filter, like the solar one it comes with. Any 2" filter will work but you might have to 3D print some kind of adapter. You also have to be careful to remove it before you shut down the S50 or close the arm.
Thanks, already ordered the adapter 🙂 cheers
Hello, currently Seestar can't install other filters, if you need to install other filters, you need to DIY a device, similar to what comes with the sun filter.
support yes already bought the adaptor for it and your filter is on the way :-)
Thingiverse.com has the .stl files for download.
