My mounts have the option to connect over BT.
Would be an improvement if you could integrate BT as option for connecting a mount to Asiair.
    Team-Deepflights If you own AM5N and AM3, it supports on 2600 AIR, for other BT mounts, may i know what is the model of yours? i will forward to our team, thanks
    Team-Deepflights
    If you're asking to add in connecting via Bluetooth for existing ASIAIR Pro/Plus (32GB and 256GB) models then I don't think that's possible because they don't come with a Bluetooth module (as far as I know).
    Raspberry PI4 (Asiair Pro) have an integrated BT module.
    For Plus I am not sure at all.
      Team-Deepflights not necessarily.
      There are Raspberry Pi 4 boards produced for corporations for different needs.
      Here's a video that does a tear down of the ASIAIR v1, the ASIAIR Pro and the ASIAIR Plus (32GB).
      https://youtu.be/nGZeZNoiRj0?si=yOce1ghOhLlsRun4
      FYI: the ASIAIR Plus 32GB is newer than the ASIAIR Pro. The ASIAIR Plus 256GB is newer than the ASIAIR Plus 32GB and is based on a different board.
        20 days later
        My understanding is that CM4 wifi module also includes Bluetooth built-in. So if this is true then ZWO must have ordered custom CM4 modules without Bluetooth. I didn't know that was possible.
        The Bluetooth can be disabled but pulling a pin low on the CM4 connector or by disabling it with dtoverlay options. Looks like it is disabled in the config.txt file ..
        2 months later
        Are you still planning to look into bluetooth supports for non-ZWO mounts?
        If the ASI2600MC Air is able to support connection to Onstep mounts via bluetooth, I would probably buy one for my 'portable' setup.
        I'm sure it's possible for Zwo to make a small Bluetooth USB dongle to connect to the AM5N, actually they should make it wifi+BT so we don't have to use the ridiculous hand controller just to have wifi connection.
        Write a Reply...
