The 224 is quite an old camera now in relative terms (maybe 4 years plus now which doesn't sound that old), it also has a tiny 5 x 4mm sensor, though it's a comparable size to the imx462 within the Seestar.
Your issue is your Seestar is 250mm focal length, your GT71 is 419mm, as a general rough scale nearly twice the focal length. So with the scope your images will be more "zoomed in", as a result you may find the signal weaker, when in fact it's spread out across more pixel area. So if you compare both, youll perceive to find the SS image brighter, but in AP if you scale comparison images to the same pixel scale you'll often find they look very similar.
You haven't mentioned how long you're imaging for. A SS I believe by default takes 10s images and continually stacks them until you stop it, for your scope how long per image and total time were you imaging for? Was it like for like time? How did you stack? Did you take and apply calibration frames?
