Hi, with LXD75 Autostar mount, when I do the PA procedure, the mount rotates by much more than 60 deg. Maybe a bit more than 90 deg. Everything seems to work fine, but I was wondering if the mount is actually properly Polar Aligned, even though the alignment angle is not the stated 60 degrees. Anyone else have this issue? Any thoughts?
Thanks!
