I see on the ads that the ASI174MM has a AR glass over the chip. Is this a UV/IR filter or is just a piece of glass to keep "stuff" away from the chip?
And last, does AR stand for Anti-Reflective?
kohamher1 wrote:ASI174 2.JPG I see on the ads that the ASI174MM has a AR glass over the chip. Is this a UV/IR filter or is just a piece of glass to keep "stuff" away from the chip? And last, does AR stand for Anti-Reflective?
yes, you are correct.
UV/IR filter used for color camera
