Hi,
Here is a first light with ASI174MM camera. Here are the imaging details:
Seeing was not good and the sky was blue, so this is not the best possible quality. This image is a part of the whole Moon panorama (it will be published later in my gallery at http://www.makolkin.ru )
First impression is very good, and I am sure that this camera will be the best possible tool for my Moon panoramas, as well as Sun images next Summer.
Thank you, Sam, for such a nice camera!
Scope: TAL-250K, D=250mm F=2130mm.
Barlow: 1.5x
Filter: R filter from Baader RGB set
FireCapture v2.4 beta Settings
Camera=ZWO ASI174MM
Filter=R
Profile=Moon
Filename=Moon_150225_164305_R.ser
Date=150225
Start=164305.962
Mid=164323.599
End=164341.237
Start(UT)=134305.962
Mid(UT)=134323.599
End(UT)=134341.237
Duration=35.275s
Date_format=yyMMdd
Time_format=HHmmss
LT=UT+3h
Frames captured=2400
File type=SER
Binning=no
ROI=1936x1216
ROI(Offset)=0x0
FPS (avg.)=68
Shutter=10.00ms
Gain=100
SoftwareGain=10 (off)
HighSpeed=off
Gamma=50 (off)
Brightness=0
USBTraffic=42
AutoExposure=off
Histogramm(min)=18
Histogramm(max)=149
Histogramm=58%
Noise(avg.deviation)=2.54
Limit=2400 Frames
Sensor temperature=20,8 °C
