I am having problems after a meridian flip. The target will be in view. but not centered. It will not plate solve and successfully center. I am using a SVBony SV220 dual narrowband filter with 2 sec exposure,
 if that matters. I do not do any star alignment with the mount, just polar alignment with the ASIair. Other things I noticed are that in an attempt to go home, RA is off about 20 degrees, declination is correct. Also, preview will not display the most recent image after the flip. GOTO is also way off. I am including a log file.
