Astrop How are you finding the scope, I was looking at it but then read all the stories about BF issues and then WO needing to send customers a new BF spacer adaptor.
The fast optics just needs very precise backfocus. Even 0.05mm off (not typo -- less than 0.1mm off) can cause corner stars to be bad. I have this adjuster permanently installed to achieve the precision needed:
https://www.sharpstar-optics.com/Products_1/83.html
I step 0.025mm at a time once I get close to the correct backfocus. Mine came out to be about 0.15mm from the advertised "55mm," once the filter glass thickness is accounted for.
Those who complained on Cloudy Nights are probably just stepping 0.1mm at a time using washers. Too rough for an f/4 -- I think they are used to slow scopes such as the Askars and RedCats.
(By the way, the scope also comes with a built-in tilt adjuster.)
Does the focus remain stable throughout a session?
Donno. Because I am used to the Baby-Q's requirement of accurate focus to achieve its small spot size, out of reflex action, I always refocus when I see a 1ÂșC ambient temperature change.
Some good detail in that image.
Very small stars once you have the backfocus adjusted.
The details are not as good as that from the 1.01x flattener of the FSQ-85 -- but then, the Baby Q can barely frame the east and west veils in the same plate! (The Baby-Q definitely has smaller star FWHM, with star colors only a true fluorite can produce.) I am waiting for the new QB 0.73x reducer from Takahashi, which should give me a 44mm image circle at 330mm focal length (the current reducer from Tak has an abysmally small usable image circle). The Pleiades 68 will probably not hold a candle to it, and will likely be retired when that reducer arrives. In the meantime, the speed of the scope, together with the sensitivity of a monochrome camera is providing me with lots of fun.
